Reworking B's PTO pulley
PatrickBeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Topic: Reworking B's PTO pulley
    Posted: 06 Nov 2015 at 6:44pm
Got a PTO belt pulley that is worn out, key way slot. Found a replacement, but don't want to give up on the old one. Thinking about recutting the keyway, or machining out a new hub. Wondered if anyone else has messed with reworking one. Seems to me someone on the forum bolted on a vbelt hub, but don't want to do that. Anyone know of the tapper for a PTO belt shaft? Hate reinventing the wheel.... Should say this is off my B.
[/IMG]
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 7:42pm
   looks like you have a puljey for the small shaft--there wer 2 size shafts small was fffffor the earlier ones   we had bush them when we installed WOODS MOWERS  NOT OFTEN -BUT HAVE SEEN IT HAPPEN
This page was generated in 0.101 seconds.
