Stuck wd
scruffy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scruffy Quote  Post ReplyReply Direct Link To This Post Topic: Stuck wd
    Posted: 23 Apr 2010 at 11:29am
I bought a wd last fall for parts and when I  went to move it this spring ,she's locked up tight. engine stuck which I knew but I can't get her out of gear to load it,Any ideas welcome.Thought maybe ice in transmission through rotted shift boot .throw in clutch and still no roll.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 12:22pm
Are you sure brakes are not locked up from nest in housing,if it is the tranny it might be in two gears at once from bad shifter. Pull the shifter out and make sure the groove in the rods are lined up with each other.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 2:09pm
Try putting hand clutch in forward position, lock foot clutch forward(released position), then try to gently rock tractor back and forth with a come-along.  I once bought a parts car from the salvage yard that had one of the brakes locked up........we pulled it a hundred yards or so before it broke loose.  FWIW............O_O
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 4:32pm
I would check the brakes too.  You can pull the cover off of each side and loosen the nut on the top on each side and then try to pull it and it should brake loose.  I had to do that on a WD I got once to get it to unload after I dragged it onto the trailer with an engine hoist.   After that experience, I bought a winch for my trailer.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 5:08pm
yep, I bought a field stored WD once that had a frozen brake
Post Options Post Options   Thanks (0) Thanks(0)   Quote scruffy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 6:56pm
I never thought about locked brakes! The guy said he drove it up there and shut it off and left it
This page was generated in 0.906 seconds.
