WD45 with WD-9 loader
Mike Pad KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Pad KY Quote  Post ReplyReply Direct Link To This Post Topic: WD45 with WD-9 loader
    Posted: 31 Oct 2015 at 5:41pm
I am looking at a couple of 45s with WD-9 loaders and was wondering how much weight the loader would lift? I am not going to use the bucket just a chain to pick up things around the shop. I can't find the specs in any of my books or manuals. I think they would probably be OK but, I have never been around a 45 with that loader.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 7:46pm
rated to pickup 1800 lbs. with a 3000 lb breakout. better have weights and fluid. I have weights and a cab on mine it will pick up the front of my 5 ton truck. No problem pickin up a 6x6 bale. Just don't plan on driving any where with it. without power steering a full snow bucket is about 900 lbs that i can steer and easily stack 10 feet high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 8:28am
It will pick up enough to turn it's self over on a slope.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Pad KY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 8:32am
Dave, thanks for the info. The one I'm probably going to buy has power steering so that will work out great. I have some weights so I should be good to go. Again I appreciate the the help to make my decision. Mike Lynn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Pad KY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 8:40am
Mack, I have a 2320 John Deere and I almost turned it over 2 or 3 times before I learned what it would do. Had a small case tractor with a loader on it and did turn it over, way to small to use handling granite like we do. Dave is right on target about the weights and fluid, makes all the difference. The older I get the more careful I am, would like to get older!
This page was generated in 0.127 seconds.
