6060 PTO Bucking |
Post Reply ![]() |
Guitarguy138 ![]() Bronze Level ![]() ![]() Joined: 19 Oct 2015 Location: South Carolina Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Oct 2015 at 2:08pm |
Hey guys. New here and new owner of a 6060. Having issues with the PTO bucking up and down. Also my level selection arm will pull all the way back but only go half way forward to the 5 mark. Having to pretty much set the level with the traction booster instead of the level arm. Traction booster is supposed to be pulled all the way back and then be able to use just the level arm to make it go up and down. Well when I do that, the dang thing bucks my bushhog up and down like a bull. Bushhog only weighs 985. Any ideas? Low fluid? Air? Seal issue? What the heck can I do with the level arm that won't let it go down all the way? Sorry for all the questions. Thanks for help for all that is given.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
No idea what you mean about the PTO bucking up and down. Regarding your traction booster, sounds like the cable linkage is rusted up pretty good. Might be able to oil it up for free it up. Best bet might be to buy a new cable linkage.
It's the position lever I'm having the issue with. Not the traction booster lever. As far as I mean bucking, once I get the implement to the level I want it. It will lose and regain pressure to where it hop up and down.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10800 |
The PTO and 3 point lift arms are not the same. I think you must be refering to the lift arms going up and down.The pto is the power take off shaft out the rear of tractor. HTH Tracy
Post Reply ![]() |
