Gleaner N5 too much trash?
Craig/insoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner N5 too much trash?
    Posted: 18 Oct 2015 at 12:49pm
My dad is running soybeans but says he's getting too many hulls and broken pieces of stems in the grain tank! He is running rotor at 440rpm concave set at 5/8" fan running wide open has long finger chaffer totally closed and sieve opened just about right not cracking any beans! 65 bu/acre 13.1 moisture not blowing any beans over! I think he needs to open concave up some more and crank RPM up to about 540-550 just not very used to rotary! Any thoughts or ideas would be appreciated has no rotor or cylinder upgrades!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 12:50pm
Start off with the short finger STANDARD chaffer......you can't expect a clean sample on an N-5 with a corn chaffer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 3:20pm
Thanks for the reply DrAllis!
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 5:18pm
are you storing the grain? if not you would be surprised what you can get by with on hulls in the tank as far as dockage. I thought I had too much but elevator didn't care so neither did I. also 13.1 is kinda wet
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 11:26pm
13 is dry so are you saying compared to most beans this fall?
