Building an 8000 series front bumper |
Page 12> |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: Building an 8000 series front bumperPosted: 02 Oct 2015 at 10:12am |
We don't run front weights on any of our big tractors so with the 8050 we decided to build a bumper to fill in the area the weights would go and protect the grill from corn stalks. It is going to bolt to the weight bracket and house 4x 4.5" led lights (2x spots, 2x floods) which will be on a separate light circuit. The toggle for the lights is a 3 position (on off on) that fit perfectly in the blank for mfwd switch. forward on the switch will be the spot lights and trailer lights which I'm adding, middle is off, rear will be all 4 front lights and the trailer lights. Light circuits will be on relays.
before cutting the beams: After: And here is the cover that will get broke and installed. will be burning on the laser today
Edited by coggonobrien - 02 Oct 2015 at 10:12am |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Posted: 02 Oct 2015 at 10:50am |
that will look good put a orange lense and light behind the a c logo
coggonobrien
Posted: 02 Oct 2015 at 11:05am |
You are close, I was going to do a clear lens with a couple orange led's shining up.
coggonobrien
Posted: 02 Oct 2015 at 11:07am |
i'm also going cut the bottom corner of the bumper slightly to match the angle of the grill
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 02 Oct 2015 at 11:11am |
Dave,
Pretty fancy corn stalk guards! Lazer cut to! Damn! Should look nice. What did ya do, take a break from the little Tractors? I like the use of the relays for the lighting. Good move... Steve@B&B |
coggonobrien
Posted: 02 Oct 2015 at 11:13am |
grass isn't growing much so i've putting off getting the complete 616 mowing again, we started picking corn the other day so I figured I should finish this. whenever it rains i'll pull the 616 motor and install the harness I got from you. I wish I had the laser at home but it is nice to be able to sneak in a piece of government work on a slow day.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 02 Oct 2015 at 11:54am |
that framework outta hold them lights pretty well! whew! it looks good tho! after yer done with that, make a rear bumper for Desert Joe! i'm putting all new LED lights on my 180D.
coggonobrien
Posted: 02 Oct 2015 at 5:55pm |
coggonobrien
Posted: 02 Oct 2015 at 5:56pm |
Bottom edge is not broke yet
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Posted: 02 Oct 2015 at 6:55pm |
Very nice work. Where are you guys getting LED lights?
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
coggonobrien
Posted: 02 Oct 2015 at 7:19pm |
Amazon cheapies
Stan R
Posted: 02 Oct 2015 at 7:25pm |
Lights look the same as what I got from amazon and put on our tractors. Really cheap and high quality. Though relays are not necessary as LED amp draw is around 4 amps (total for both lights).
Edited by Stan R - 02 Oct 2015 at 7:32pm |
coggonobrien
Posted: 02 Oct 2015 at 7:28pm |
Yeah 10-15 per light
SHAMELESS
Posted: 03 Oct 2015 at 3:04am |
I left the relays out on my LED's too!
Stan R
Posted: 03 Oct 2015 at 4:17am |
JayIN
Posted: 03 Oct 2015 at 4:38am |
Very, very nice! I am impressed ! You are giving me ideas!
coggonobrien
Posted: 04 Oct 2015 at 8:09am |
SPS in WV
Posted: 04 Oct 2015 at 3:50pm |
You do nice work, that looks good.
coggonobrien
Posted: 05 Oct 2015 at 6:36am |
Thanks, it's coming along, aesthetically it would of looked better shorter but wouldn't of protected the grill like we want it to.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 05 Oct 2015 at 8:41am |
That is a great idea.. From viewing Norm's book, it appeared that AC's early proposed 7000s styling included grill lights, but were later deleted when final style was decided upon?? I always felt that the 7000s & 8000s needed more front lighting. Now you have it. Good job! And, I love the laser cut AC..
Edited by AC7060IL - 06 May 2017 at 7:26am |
coggonobrien
Posted: 05 Oct 2015 at 8:48am |
I would of like to carve a shell that would fit the upper grill but I don't like the idea of possibly drilling holes in the screen
tornado8070
Posted: 05 Oct 2015 at 12:33pm |
Nice idea. Are you going to paint it?
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
coggonobrien
Posted: 05 Oct 2015 at 12:35pm |
Yeah it will be black
tornado8070
Posted: 05 Oct 2015 at 1:35pm |
nanuk
Joined: 22 Aug 2013 Location: Saskatchewan Points: 258 |
Posted: 11 Oct 2015 at 6:52am |
I don't think it is heavy enough.... it'll never handle the weight of those lights! She'll shake loose in no time
AC7060Pd 1975
coggonobrien
Posted: 12 Oct 2015 at 1:38pm |
coggonobrien
Posted: 12 Oct 2015 at 1:40pm |
matador
Posted: 12 Oct 2015 at 9:29pm |
Now those are bright lights! With the roof lights, you could light up the entire field!
coggonobrien
Posted: 14 Oct 2015 at 6:55pm |
coggonobrien
Posted: 16 Oct 2015 at 8:49am |
Page 12> |
