AC B Hyd Pump
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC B Hyd Pump
    Posted: 21 Sep 2015 at 10:41pm
Can I remove the check valve ball and replace it with out removing the pump from the tractor? If so where is it located?Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2015 at 10:02am
Bump
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2015 at 9:07pm
The pump intake and exhaust check valves, yes. The hold/lift/relief valve, no. The H/R/L valve falls out after removing the control lever and can't be reinstalled until it's seat has been driven out of the housing. The seat's position in the housing also sets the relief pressure, so measure how far it is driven in before you drive it out. Very simple pump, but kind of a pain to set up off of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2015 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2015 at 9:57pm
Thanks
Ted
