D15/D17 diesel injection pump leak ?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: D15/D17 diesel injection pump leak ?
    Posted: 21 Sep 2015 at 9:48pm
My injector pump is leaking at the governor shaft. How much work is it to fix? I assume the pump has to come off to get the shaft out??
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 10:23pm
A couple years back we had mine apart at the Amana IA A-C show. I think if you are careful and clean, you ought to be able to take the top off without removing the pump from the engine.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 11:01am
If I remember correctly the shaft comes out in halves and will come out while the pump is on the engine. I believe the shaft seals are o-rings, but it's been a while since I've had one apart.
ksbowhunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 9:16pm
Yes the shaft is a 2 part shaft. They are easy to do on the tractor and have done a few that way.
2-37 WC
37 wf127
37 wf130
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 9:26pm
Thanks guys, leak seems to have stopped for now....maybe it just needed to get warmed up and used a little more!
ALLIS EXPRESS!
This year:
