Timing question
Tractornewb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Topic: Timing question
    Posted: 20 Sep 2015 at 4:02pm
On my d15 I know where the hole to shoot the light is but all I can see is side of fly wheel ? Any direction as to where to find the marks ?
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 4:19pm
The marks are on the flywheel.
"F" at 25 deg. BTDC, and "CENTER" at TDC.
I like to paint the Fire mark with white paint so I can see it easy with the timing light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 4:30pm
Hmm looking thru that hole I can see smooth side of flywheel and the ring gear but no marks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 5:01pm
Carefully shove a large flat blade screwdriver in the hole while the engine is idling and hold it against the flywheel to scrape the rust off of it. Engine must be running WIDE OPEN throttle to adjust timing to the F-25 or FIRE mark. Always mark your distributor before you start changing things so you know where you exactly where you started from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 5:30pm
I appreciate your help I did that with screwdriver. I must be missing something I just can't see anything on the wheel. It's defintaly straight on thru the view hole on the SIDE of the flywheel?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 5:50pm
Side of the flywheel, yes. You must have the engine wide open speed and then maybe adjust/turn the distributor back and forth to get the flywheel mark to show in the center of the hole. MARK YOUR DIST BEFORE YOU START TURNING IT BACK AND FORTH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 6:10pm
Thanks so much doc for walking me thru that yup just moved a little and saw the mark ! Turned it back a little first it started to studder. Turned twoards the front and it ran great. Unfortunately I'm outta gas on it now and dark outside but will get it set tomorrow. Thanks again doc
Dan73 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 6:11pm
Double check that your timing light is hooked up to the sparkplug wire for cylinder #1 in the very front of the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 6:18pm
It was thanks though. Ran the damn thing right out of gas as soon as I turned that distributer forward it sounded so much better can't wait till tomorrow !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 6:34pm
Well don't feel bad I put 40 gallons through my d17 the last two days haying. It is a real bummer when you just get going on a project like that and run out. Sounds like tomorrow you should get some good results.   Keep smiling it isn't snowing yet...
Edited by Dan73 - 20 Sep 2015 at 6:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractornewb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 6:45pm
Got that right!
