New To Me 1950 WD With Loader
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: New To Me 1950 WD With Loader
    Posted: 08 Sep 2015 at 6:48pm
I was given a WD that has been sitting outside for the past 7yrs. I drained the water out of the gas tank, carb and oil pan. I then added 4gals of fresh gas with sea foam and fresh oil with mystery oil & cleaned the points. It took about an hour to do it. As soon as I hit the starter it popped right off. I had to run it with the choke on for 15 mins. After that it ran smoothly with no choke. What a day!!
Thanks & God Bless
Dennis
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 8:44pm
    Nice one Dennis .
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 9:36pm
Noone gives me cool things like that...
Great to see you got it running again before it sat so long it wouldn't run. Nice tractor there.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 9:38pm
that Mystery oil is sum good chit!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 8:26am
Congratulations on your good luck (and obvious knowledge of how to get an old tractor running again)!  Looks like you've got a nice new outfit to have a little fun with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 7:17pm
I tried to move it today under it's own power and found that the hand clutch would not stay engage. So I took the loader off and pulled the cover and this is what I found. Not only is there no oil but someone had started working on it and quit. Note the top bolt is missing in the collar assy.
After working on it most of the day I took a few pictures for all to view. It's really sad that someone would just let the oil leak out of the PTO seal and not just replace the seal. I can not do anymore until the new parts come in from AGCO.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 7:29pm
Looks like you had a busy day. Sad to see the problems that neglect and poor work caused but it is good to see someone dig right in and make it right. Keep up the good work and keep us updated it is always nice to see these projects progress.   It gives me currage to attack my own equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 7:05am
Dennis,
Exterior looks better than the insides. Good job getting right after this problem. I have not split one and pulled the front end forward. But have changed the brass collar in both WD's. Hope this is the extent of the issues. Is the tranny OK with fluid? Rear end?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 8:07am
O-well one nice part about the tractor is the cost is not high. I'd find a used WD45 three disk hand clutch and rebuild it. Check the end play in the hand clutch input shaft. Might sit down when you get the price on a new brass collar.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 8:33am
Great pictures!  I've heard that it could be split using long bolts but never seen pictures until now.  Thanks!Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 9:08am
After looking at all the rust inside you night drain the oil and remove the shift cover, rear end back cover and take a look around in there too before spending money on the hand clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 9:39am
wow...that is sad!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 11:31am
Rear end and trans are good. The hydraulic fluid was low. Water got in the hand clutch area from the cover being pulled off and put back on with no gasket and the bolts where not tighten down.
I do have a good use collar I got off of ebay years ago for $9.99. I think AGCO's price is well over $150.00. As long as the collar rides in oil have very rarely wear out.
Wrenching on a tractor all day is still a good enjoyable day.
Thanks & God Bless
Dennis
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 5:08pm
Nice job setting things up to separate that tractor. Gives a good example for me & others to follow. Thanks.
Ray W.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 6:36pm
That's good news on the back haft and more good news that you have a backup collar just weighting to get back inside a WD. I hope you can find all the replacement parts laying beside the E-bay collar. lol
Yes you are right a even bad day at home working on the toys is far better that the best day at work will ever be!!!!!
OK Dennis I think it's time for you to be a movie star and make a video on rebuilding and setting the hand clutch up on a WD/WD45; so how-bout it, I know you can do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 2:05pm
I did want to put the WD-45 hand clutch assy. in the WD.
But when I pulled the cover for the parts tractor and found this.
Looks like years of condensation have been at work.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 2:11pm
That's no good the parts tractor looks worse then the tractor you are fixing.     now you need to find another parts tractor.... I am starting to see how we end up with a collection of these things in pieces...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 2:28pm
Man,I have had days just like that too. Have you opened up your old two disk clutch, if you have a bead blaster it might clean-up with some blasting work and be usable.
If you need some used parts and can't find them I have some in the parts trailer someplace.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 8:25pm
Dennis you should put a new seal on the shaft going thru the housing. Hopefully the piece that holds the brass collar will separate from it. You will have to put the tractor back together again, and take the right frame rail off. The seal I used was 9878 by SKF. That will keep you busy. lol Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:53pm
Yep, that's the plan. I have all the gaskets and seals needed. I just need to finish the hand clutch so I can get it back together. I'm not looking forward to the front pedestal bolts. They like to brake off.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 11:25pm
I split the parts 45 today and took a few pictures of how I set it up.
I used four 3/4-10 threaded rod 18" long with nuts on one end.
I then take out the rail mounting bolts and replace it with the rod. Replace one at a time. Do not remove all the bolts then put in the rods.
Also place a jack under the tube casting to support the weight. The rods are to support the trans and read end from tipping.
Once all the connections that bridge between the back and front of the tractor and all bolts have been remove you can roll the rear end back.
Thanks & God Bless
Dennis
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 7:11am
What is the rode with the chain on it for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 7:31am
That is the snap-coupler release lever.
Thanks & God Bless
Dennis
Dandan111 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dandan111 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 10:46am
Dry as a bone. Sad. Wish every tractor could be kept inside. We would have better
Old tractors!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 10:51am
You have done a fine job showing what you did to spit the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2015 at 5:26pm
I took apart both the WD & WD-45 hand clutches and here is what I found.
The 45 clutch had heavy rust oil deposits. Currently soaking in solvent so I can compare and check parts better.
The WD clutch likes far better than I thought. very little rust or oil deposits. I may just add a center disc from the 45 clutch to this WD clutch and call it a day.
Edited by DennisA (IL) - 13 Sep 2015 at 5:27pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2015 at 6:37pm
Some of you may know by now that when I'm working on a project what ever I come across that show any sign of wear I feel the need to make it right.
Well I found the brake & clutch shaft was worn as well as the clutch and brake pedal pivot points. So I sent them off to the machine shop for some attention.
A new shaft was make.
Then the pedals were bored and bushed.
Now just need to make sure they are greased as needed.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2015 at 6:40pm
Nice work. Good to see the attention to deal.   A lot of guys would have figured the old ones would still work but like you I like to fix it right the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2015 at 10:06pm
Dennis,
I too say thanks for showing how you split the tractor....every educational!
Mike in Iowa
grateful1micelf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grateful1micelf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2015 at 7:54am
yes, appreciate the pictures and info. always nice to learn new things and also see these good old tractors getting back in service. great job!Thumbs Up
