7010 Radiator foam?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Radiator foam?
    Posted: 08 Sep 2015 at 7:09am
Radiator keeps getting plugged up with chaff while mowing tall weeds, and I noticed that there is no foam on the sides of the radiator.
Will that help, and where can I buy some?
Thanks,
Roscoe.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 7:35am
I cut foam outta old couch cushions to fit. may wanna put a screen over the radiator when doing some work
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 7:39am
Agco dealer has the preformed foam kits, but I get mine from Hy-Capacity,they are cheaper. The foam will help, but in your conditions, frequent cleaning will probably be required.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 9:15am
Thanks guys.  I ordered a set from TractorJoe.com
It was mostly leaves and large chaff, so I am thinking the foam seal will stop that.
- Roscoe.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 12:47pm
If you are running in a lot of chaff, try putting a very fine wire screen over the front grill.  This will keep the fine chaff out of the radiator for the most part, and make cleaning very simple, since it will happen a lot in the conditions you describe.  Shut the engine off, wipe it down with a glove, and go back to work.
Still in use:
