B adjustable front axle
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: B adjustable front axle
    Posted: 31 Aug 2015 at 7:56pm
Used 1940 and up
Mine don't look right. The whole axle assembly appears to be leaning back at the bottom making the B look like it is tip toeing. The spindles are nowhere near vertical, leaning forward at the top and back at the bottom.
This old B has had a rough life and the wishbone is probably bent. Any easy way to fix the problem? I think if I cut the pivot bolt that is inline with the wishbone off and weld it back on top of the wishbone it will cure the problem by dropping the back of the wishbone down about a inch.
I actually have two Bs with the same problem
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 9:10pm
Pictures would help. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
