Changing the fan belt on a 175D
old AC friend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old AC friend Quote  Post ReplyReply Direct Link To This Post Topic: Changing the fan belt on a 175D
    Posted: 30 Aug 2015 at 9:10pm
Have never done it before.  If I remove those 4 bolts from in front of the crankshaft pulley that holds the drive shaft that runs the hydraulic pump, will that connector slide forward enough to put the fan belt on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 9:39pm
Yes it will. Hope your splines are still good. They wear pretty well. The little snap ring might have to move if it is real close. Depends on how far shaft is in front coupling.Grease the chain while you are there. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote old AC friend Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 2:25pm
Thank you for help, Tracy.  I don't know what the splines are but I would guess they are the bushings around the bolts and they have been gnawed on pretty good.  AGCO tells me they are no longer available.  Do you have any ideas where I can get replacement parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 2:30pm
The splines are inside the hub, and on outside of shaft. They are what drives the pump from crank pulley once you install the snubbers(worn pieces you refer to) . You should be able to get them from a John Deere dealer, I think they are what was used on a 3010 pump also. The id will need to be enlarged some.A good counter man will know what they are if you take one in. HTH Tracy
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 3:53pm
Or you can do this!!!!!!!!!Put a link belt on it! Fast and easy!!!! We have ran this style belt on our forklift with pump drive for years & Thousands of hours and its still good as new. Most Industrial places carries it. Here's link to one of the manufacturers.
http://www.fennerdrives.com/nutlink/_/NuTLink-B/17/5L/
http://www.bdhbelt.com/link-v-belts.asp
Edited by farmtoybuilder - 09 Sep 2015 at 3:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 3:59pm
This page was generated in 0.477 seconds.
