late 175 diesel pump snubbers
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: late 175 diesel pump snubbers
    Posted: 28 Aug 2015 at 4:38pm
away from shop and customer called, Tracy or others, any alternate source for the 4 rubber inserts   70256040 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2015 at 8:37pm
tbran, I bought mine from a john deere dealer.Can't remember what tractor they were used on, maybe a 3010. Had to increase the ID hole though, no big problem. HTH Tracy
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2015 at 9:02pm
i' think'in they are all the same....
Ron Tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Tn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 7:25am
Tim, we  use Tisco #291061 hub kit. You remove the snubbers and put them in the AC hub. You may have to grind down the metal bushing inserts to make them the right length.
