WD45 shifter tower
Fish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fish Quote  Post ReplyReply Direct Link To This Post Topic: WD45 shifter tower
    Posted: 19 Aug 2015 at 7:20pm
Having trouble removing the shifter tower. Appears the reverse fork is holding it up. Last time I drove it it dropped into 3rd gear and I could not get it out. Any advise out there?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2015 at 8:01pm
straight from wd45 service manual.
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2015 at 8:32pm
Remove the shift boot. Take out the snap ring and retainer. Pull out the shifter. Do not drop the pin(s) that are in the shift tower. Stick a long screwdriver or something similar down in the hole and pry the fork to the neutral position. Then reinsert the shifter. When it is in neutral the forks will make a rectangle shape that will look a little like this ---> [ 0 ]
when you have the shifter in correctly you will feel a little spring tension on it when you move it side to side. You probably have a worn shifter on the end or where the alignment pins are.
Edited by irlbeck A-C'S - 19 Aug 2015 at 8:37pm
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
Fish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fish Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 5:49am
Thank you I will give it a try.
