7080 Water Pump |
Post Reply ![]() |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5601 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Aug 2015 at 11:58pm |
How does one go about getting the spacer off of the pump shaft? It has been on there a day or two and doesn't want to come off. Do I dare use heat?
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
press? uh...what spacer? behind the pulley mount? I've taken one apart before to put the new kit in it, but don't remember any spacer...
dpower ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Madison Ne Points: 1578 |
your getting forgetful Shameless
Edited by dpower - 13 Aug 2015 at 2:41am |
ya think?
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2389 |
Sometimes those can be an absolute bitch. Plenty of penetrating oil, heat and beat, and I use a very thin screwdriver or stiff putty knife driven between the pulley and spacer.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Have a helper hold a heavy block on one side while you use a dull chisel on other side. p MACK
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
I use a 20 ton press with a split bearing puller behind the spacer, keep tightening the bolts on the bearing puller halves as it goes.
It is off. I used heat and little by little, she came off the end.
Post Reply ![]() |
