F2 Engine loss of power
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: F2 Engine loss of power
    Posted: 08 Aug 2015 at 6:57pm
Gleaner experts,
I have a new one that is stumping me.  I was running oats today, and all of a sudden I lost power.  I first felt the cylinder slow, like it was plugging, but I was in clean grain, so I was perplexed.  I tried to increase the throttle, but it would not go up.  Instead, the engine RPM would just steadily decrease until the machine quit.
     My first instinct was that I had a loss of fuel, so I checked the sediment filter, and the glass bowl was clean, and the screen was clean.  The canister filter was just replaced at the beginning of the season, so I assume that it is not the problem.
     After I let it rest for a while, the machine started right up, and ran for a little while, and then the same thing happened.  I then thought that the tank might have an obstruction, but the glass bowl was full, with no air pockets.
     I let the machine rest, and then walked home, and got my wife to bring me back to the machine, and follow me home.  Sure enough, it started right up, and then partway through the field (read 1000 feet), it started to lose power, and then shut down.  My wife who was behind me said that she saw lots of white smoke coming out of the stack at the same point where I was beginning to lose power.
What is happening?
Any thoughts?
Thank you
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 7:00pm
Gas or diesel?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 7:01pm
Diesel, sorry.  It has the 4 cylinder engine
Spelt Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spelt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 7:37pm
Did you take a peek at the coolant level? White smoke makes me think it could be burning antifreeze.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 8:11pm
Oil and coolant are full.  My thoughts were coolant as well, but when I let it cool, I opened it up, and it was right to the cap.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 8:23pm
White smoke can also indicate plugged air intake system.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 8:45pm
Maybe the governor ring plugging the return check valve in the injection pump. Have had it happen to a D-21. Common with RoosaMaster pumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 8:50pm
Calvin,
Is this what I have seen InjPumpEd mention before as well?  I can take some piece out, and it will run, but it needs to be rebuilt after that?  I don't recall the posts, but I do recall something about this.
John
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 9:03pm
on the side of the pump there is a small plate with two screws when she lose s power loosen them up and try starting it up  if your power is back its probably is the govner ring on the top of the pump is the return fuel fitting (should be 1/8 pipe ) barb fitting take it out and put in a regular one finish cutting oats and then take the pump off and send it along with the original fitting to injpump ed  before you start corn this fall as the pump needs to be rebuilt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2015 at 9:03pm
The is a little ceramic check valve ball on the T on the fuel return line. If you knock out that little check valve ball you will be OK. When plugged, it will build pressure inside the pump until the plungers don't function and the engine stops. Pressure will drop after a few minutes and the engine will restart. Can also bleed pressure out of the side of the pump. Without the check valve it will run fine but you are looking at a pump rebuild soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 11:05am
Bradley and Calvin,
I opened the little access panel (two screws, and fuel came bubbling out).  Inside I saw two metal items, with a vertical space between them.  Otherwise it was all clear.
In the return line, I pulled the fitting out, and could see the glass ball, and it was clean and clear.  I used a coffee stirrer, and the spring moved when I pushed on the ball.
So if I remove that piece for the last on my oats, I should be able to run, with out the engine dying?
Thank you,
John
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 11:47am
Calvin and Bradley are spot on. Also, the advance goes to full retard when the housing pressure gets high enough to make it lose power, so that is why the white smoke. Gut the fitting that has the glass ball by grinding the inside end down enough to pry out the washer that holds the ball and spring in. Then, finish the job you're doing. Then in the off season, get the pump rebuilt. While the fitting is off, make sure you can blow air back to the tank through the return line. You may have a blocked retun line somewhere on the machine.
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 12:29pm
Did you check the air filter?
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 12:47pm
Air filters are a funny thing this spring we sold our f2 the new owner started home got 40 minutes away it cut out replace the fuel filter started up ran for 10 min stalled A buddy with the new owner was persistent about the air filter to it off and the machine ran fine they drove it home four hours away with out the air filter
The point is I would never thought the air filter was plugged so for a easy quick check pull out the air filter
Morley
Farm stuff 8050,6690,175,F2,5050,WD
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 4:49pm
I make service calls to all our drilling rigs.
Mostly caterpillars. I'll always tell them to change fuel filters first and check air filters. 9/10 times it fixes problem. Our diesel tanks have big filters then each engine has a fuel water separator filter, then has the factory primary and secondary fuel filters. We get a load of 8,000 gallons and it stirs the tank up plugging filters. These electronic cat smoke whit with the loss of fuel pressure. I'm sure it's probably your pump but I would change filters first. It's cheap to try.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 5:59pm
My dad's 185 did the governor ring thing quite a few years ago already.  Had the classic symptoms.  Got it rebuilt in Sun Prairie and it has operated flawlessly since.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 6:14pm
yep...check/replace the air filters! and fuel filter(s)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 8:26pm
Thanks for the help everyone.  The air filter was clean.  I am pretty vigilant with those, as combining is dusty work.  I took the return tank line off, and blew through it, with no problems.  Then I removed the check valve, and sure enough, when I got the snap ring out, the glass ball was surrounded by black grit (kind of crunchy, but could break apart between my fingers).  Once that was clear, the combine ran great.  Finished my last oats, and got them unloaded.  Tomorrow I will take the head off, get the combine into the barn, and start the removal process, and send the pump off to be rebuilt.
Thanks again for everyones help.
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 8:36pm
The rubber elbow to the air cleaner sometimes suck in & cut the air off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 9:04pm
if you have any question contact injpump ed you will get great service on a rebuild from him also consider pulling the injectors once the pump and injectors have been redone you will be set to go for a long time
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 11:07am
did you try running it with out the air filter in if not how do you know that it definitively not the air filter
The only reason I am persistent about this is that like you i was certain about the air filter not being a problem as it was always cleaned out changing crops from soybeans to corn
Regardless when the new owner checked the filter it look clean until it was taped on the ground and it was full of small mould spores from the mould black corn. Once it was removed the f2 ran fine
Morley
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 11:14am
did you guys not read his update? He knocked the ball out of the return, and it ran great so he could finish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 11:21am
sorry Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 11:34am
Originally posted by wheatbreeder wheatbreeder wrote:
sorry Ed
lol! no prob!
