D-14 starter bendix woes
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: D-14 starter bendix woes
    Posted: 06 Aug 2015 at 1:41pm
Friend had her D-14 starter pro rebuilt($$$) yet would still 'whirrrrrrrr' and not engage.
So I gave her one of mine( 6V style) to get her 'up and running'.
Took me 2 hours to fix  the brand new bendix unit to cure the problem. Seems the 'gear' part was jammed all the way back( to the spring) so it'd never go forward to mesh with the ringgear.
Turns out the thread of the 'shaft' part that the gear screws on wasn't machines correctly. The groove was 'tapered' or 'pinched' at the end. 2 hours of filing later it works fine.
Sad thing is this is the THIRD bendix unit she'd tried($ $ $ ).
BTW it is 'fun' to get the armature past all the brushes .
Just thought I'd pass the info along.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 3:25pm
Its not the drive assy. It has the wrong arm in it....
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 5:41pm
Talking about getting the armature past the brushes, it was tricky getting the armature back in under the brushes on my 8N. Not sure if the starters are similar, but on mine I used toothpicks to hold the springs up so I could get the armature back in.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 6:51pm
Had same problem on my B.Put a spacer (rubber)behind gear and it works as a cushing. Works fine now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 7:25pm
re: wrong arm
hmm.... maybe I should tear all 3 6V starters off and compare? hmm... just looking at the pictures in the D-14 Dealers Parts cat and the one in question looks like the 12V version for brushes and has a 'long shaft' armature. though the case has a 'cover band' for the brush area.but... it does have the center bearing plate/bushing There is no tag on the motor. The drive gear is 10 teeth though,same as my #1 D-14. I know #3 is 12V , different ring gear and 11 tooth gear.
My 'idea' was that the 6V starters all had 'cover bands' on them and the 12V ones didn't.Sigh, this is getting 'complicated' and the new kitten likes to help me type as well....
Great... now...I'm really confused and  I have more  things to figure out.... but at least all 4 do start !!
Jay
