trail run D-14 with new shoes
Ed&Sherry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Topic: trail run D-14 with new shoes
    Posted: 05 Aug 2015 at 5:58pm
we where where able to find a pair of combine rims and 26 in tire for the D-14,,got them on and went for a load of hay [if some one can post a pic for me off cell phone you will see the results 607 972 6443 ] thanks Ed
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2015 at 10:52pm
I wanna see a pic!
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 6:55am
Ouch! Glad you are ok Ed!
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 6:58am
Now everybody wants to know "the rest of the story".....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 7:23am
Man I sure hope everyone is OK cept for needing a new pair of jeans.
Yes, please explain HOW it happened so no one else has to 'right' a D-14.
Jay
got 4 D-14s, wifed kill me if a 5th showed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 7:38am
well , just put the combine tires on ,and before dinner I,ll try them out,,went to the top of the hill to bring down the load of round bales, coming down everything was just fine, tractor holding back good ,,back fireing a little,,than the tractor went to an idle,i looked back to see the hitch had broke and the wagon about 6 in from hitting thr rear tire, when it hit I bailed,,,the rest is in the pic,,,,, thank Glenn for posting
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 8:50am
Glad you are Okay.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 8:58am
Dang, Glade that you made it off unhurt! Most aren't that lucky!!
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 9:33am
I am glad you got off in time.  You are so lucky or someone was looking out for you.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 4:06pm
Wow I agree with everyone else glad to hear that you made it off ok. Once you get the d14 running you will have to get good at backing down the hills...
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 5:14pm
Wow, you sure were lucky. I remember reading about an accident like that in NY w/in the last two years that killed the guy. He had to much weight in the hay wagon, brakes not adjusted right, and steep hill. It pushed him and jack knifed. I weighed a dry 4X4 round bale. It weighed 550 lbs. You've got more in that wagon than your D14 weighs I think. Plus that's a thrower wagon, there's a lot of weight to hold back empty. Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 5:29pm
Tractor data shows a weight of 3500 for the d14 so you are right the hay alone would out weigh the tractor.   That has me thinking as I was planning on pulling a hay wagon with my d15. I hadn't really thought about that because we always just used the 100hp 4wd Same tractor to pull the hay wagon back in the good old days. I think that was because you where lucky to get a Same to do that much work. The difference between a Same and a Deere is with Same you did get what you paid for.
Edited by Dan73 - 06 Aug 2015 at 5:30pm
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 6:59pm
may I ask how steep the hill was?  Also, can someone point out some good literature on tractor safety?  Seriously, I know how to repair these things, but I'm a city boy, I could use some literature on how to be safe on tractors.
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 7:13pm
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2015 at 8:02pm
Wow glad you are OK. Friend did something similar with a 400 bu gravity bin that was too heavy for a D-14 but only ended in a jackknife with a damaged hood section. This is why my new 600 bu. gravity wagon has four wheel surge brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2015 at 6:29am
After reading this thread and wondering about HOW you're going to get the D-14 upright, I gotta bump up the priority to get working brakes on my 6by10 tandem dump trailer! I only use it to haul horse manure 3 miles at < 25MPH BUT I just spent $$$ putting ALL new brakes on my 97 F150.
Would like to see pictures of you getting her back on all fours .
I'm thinking you lock the front axle, then pull it sideways ?
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2015 at 6:34am
I am guessing it is already up right.   I would have tried to block the rear tires. Then hook a chain on the front somewhere and pull it backwards and up with a center of rotation on the back wheels. That is how I flipped my 4 wheeler once.
