WC arb on D17
David Terry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Topic: WC arb on D17
    Posted: 28 Jul 2015 at 12:45pm
I have a wc carb I'm trying to fit to a D17 engine.  THe Carb fits OK, but the governor on the D17 moves toward the front and the carb hits the stop thus not moving.  I looked at pictures of D17 carbs and they seem to work the same way as the WC.  Could something be backward in the Governor?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 1:13pm
A WC carb is going to be waaaaay to small to feed a D17 engine. Governor works the same on all W series engines so I'm not sure why it won't work as you're stating though. Post pics will help
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 1:48pm
I went over to Jim Campbell's and looked at his D17.  It convinced me that I either have a Gleener governor, or mine is hosed up some way.  I'm going to try and locate a  proper D17 governor.  Thanks, DAve
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 1:50pm
A Gleaner governor won't have an arm to come to the carb like a regular carb since they had a throttle cable directly to the carb. What's the serial stamped on the block behind the carb?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2015 at 4:41pm
Well, I changed the front plate on the D17 with a WC which has the lever.   My problem was the linkage between the governor up right shaft and the carburetor was too short by about and inch.  I build a longer link, and problem solved.   Thanks for the help, Dave
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2015 at 7:10am
That link is very sensitive... Did you have to fabricate the original one? I have been there and done that... Finally made it adjustable with a turnbuckle. No more searching of the governor or lack of throttle.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
