D 15 II Steering Shaft Support
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: D 15 II Steering Shaft Support
    Posted: 13 Jul 2015 at 8:41pm
227768-9 and 227770-5
Seems to me like this should be an easy one.
Where in the heck does that bracket screw into the block or maybe I should say where does it mount?
thanks
Edited by Dave H - 13 Jul 2015 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 8:44pm
not a number expert, but I think they bolt to the side rail, IIRR
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 9:09pm
Dave, after I re read my post it is vague.  I am referring to the steering shaft support that I think goes on portion of the shaft that is closest to the where the shaft connects to the front pedestal.  I have the block with the bushing in it and the bracket.
it has just been so long that i don't remember where the bracket attached.
I will be looking at the inside of the side rail as you suggested.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 9:26pm
It actually goes closer to the torque tube.  The shaft does not need any support where it goes in to the coupling on the front end.
Look closely in this pic.  At the right side of the frame rail, you will see the stud of a bolt in one of the holes - that is the bolt that secures the block in question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 7:12am
Thanks Myron, that makes perfect sense.
By the way, how did you get that sediment bowl assembly shined up like it is ?
How about those fasteners like on the side covers.  They really dress it out.  If stainless, is there a source you would recommend.  Locally I don't think I would be willing to get the piggy bank out to buy them.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 9:03am
WHEW,,,,that right there is one fine, fine, looking tractor,,,,,!!!
This page was generated in 0.191 seconds.
