Anybody using N H 5070
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Anybody using N H 5070
    Posted: 09 Jul 2015 at 7:50am
Anybody bale with new new holland 5070 with thrower. Doesn't seem to throw bales far enough. Was told to change pump pully to smaller pully to spin it faster. Wandering if anybody else ran into this
Thanks
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 5:33pm
Mike,
we use a 5070.  We can clear the wagon very easily with the belts on high.  The smaller pulley sounds like a possibility, but could it be something else?  Are the thrower jaw springs tight?  If the upper belt springs are too loose, it will not give it the extra push.  A neighbor had a 575 with thrower, and his upper springs were broken, and it could not get speed enough to send it far.  My book says the roll drive belt spring should measure 11 inches between hooks.  The book also gives these possibilities:
PTO speed to low
PTO slip clutch set too light
Pump drive belt set too loose
Throwing belt too loose
Throwing belt roll speed too low.  (test hydraulic system with a flow meter and pressure gauge.
The book also showed the following problem: Trows bales too Far, will not load front of wagon.  One Possible cause is stated as Throwing belt speed range too high:  Correction says to Install shims between the sheave halves of the sheave on the motor.
So perhaps you have shims installed, that need to be removed????
Hope this helps.
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 8:58pm
Good point should make them do the trouble shooting page before put that pully on
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 11:22pm
is the belt worn? the one that spits the bales?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 11:43pm
Lol she's brand new. As of now has 1111 bales through her
