Allis C
ajec1947 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajec1947 Quote  Post ReplyReply Direct Link To This Post Topic: Allis C
    Posted: 01 Jul 2015 at 7:07pm
I am in the process of painting and redoing a 1944 C. Had the Carb rebuilt and it started good. Removed the gas tank and painted. I installed a new wiring harness and new battery cables. Now it does not turn over fast enough to start and sometime starter will not engage without bumping it several times. Checked the battery and it shows 6.38 volts. Does starter need rebuilt? any ideas. Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:42pm
If you painted over the spot where the ground cable is fastened, that will affect your starter performance.  You need to scrape the paint off of that area and shine it up with some sandpaper.  I would check that first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:46pm
x2
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 8:20pm
I concur.  The 6 volt system needs an excellent ground to function properly.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 8:24pm
also, if you took the starter out and painted it, it will need the area that slides into the torque tube paint and rust free. Inside of the torque tube too. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 9:03pm
And also, if you replaced the cables, 6V cables are normally 1 gauge. You can go larger if you want, but make sure the new cables you purchased are not 4 gauge for 12V. They will be waaay to light for the job... HTH
Steve@B&B
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 9:06pm
Hey Bob, If the starter could get its ground from the hole the starter slides into you would never need to tighten a battery cable to the battery. It gets the ground from the lock down locating stud in the side.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 10:24am
Yeah, those cables need to be as fat as Goucho's Cigar!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:05pm
Groucho.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 8:53pm
Dick, the bolt is mounted  through the torque tube which is also where the starter is slid into. They are one and the same.
If you didn't connect the battery ground cable to the battery you would have an incomplete circuit and nothing would work. Bob
Edited by Chalmersbob - 02 Jul 2015 at 8:53pm
