190 xt; injectors or pump?
PA Luke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA Luke Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt; injectors or pump?
    Posted: 01 Jul 2015 at 1:55pm
My 190XT is running a little rough.  I went through the usual suspects; fuel treatment, filter, sediment bowls, etc.  It still runs a little off.  It isn't bad and sometimes I have to listen for it.  It seems to be more pronounced when asking for power and when going down a hill it is barely noticeable.  I also put some Dextron through it and drilled out the check valve in the return line in the top of the pump and still no different.  I also tried adjusting the timing but that's not it either.
My questions are;  Should I replace all of the injectors before I have the pump rebuilt?
And;  is it going to hurt the tractor to run it like it is in the mean time?
I appreciate any help on this.
Thanks!
Luke
injpumpEd View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 2:36pm
obviously the best would be to have the pump and injectors serviced by a competent shop. If doing only one first, then with a miss-fire situation, I'd do the injectors first. If you continue running it with a dripping injector, it can score a piston/sleeve. Are you sure the mis-fire is not a mechanical issue, like valves? Check the lash, and make sure the pushrods are all still seated in the rockers. I've seen a few times where a rocker comes off the pushrod, and they chase a miss thinking its fuel related.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA Luke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 2:48pm
Thank you.  I will check out what you said.  If I need to have my pump rebuilt is there someone you suggest?  I imagine I would have to send it away.  I don't think I have any place local I can have it worked on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 3:17pm
I know a guy! lol!
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 4:38pm
Ed is the guy to go to for injector stuff. heck even just asking him a question puts you on the right path!
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 6:20pm
yep...ED is the bestest!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:48pm
Seeing that you already drilled out the check valve, it would be best to have the pump rebuilt sooner than later.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 9:42pm
save your self a lot of time deal with ed you will get great service from a true professional the injectors and pump probably need service any way with there age then there eliminated as a future problem
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:19am
If you have to send it away, may as well send it to Ed. I learned a hard expensive lesson doing otherwise. Darrel
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:36am
GO WITH ED!!   You will not be disappointed I promise you that he is an excellent man!
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:46am
Do yall know a different ED than I do????!!!!  LOL, jk Edward!
Slade
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:47am
One of the things I've learned since being a member of the forum is that dealing with the forum sponsors not only supports the guys that support our forum, but they also care enough to offer technical assistance and other help when you need it. Without exception, they seem to be a very reputable bunch. After all, they bleed orange, like the rest of us!
Since most of the tractors I fool with are older gas engines, I haven't dealt with Ed, but when I read the recommendations of everyone on here, next year when I redo my 185, he will be the guy I go to for injector and pump work.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:50am
I'll give another vote for Ed.  Very fair and has forgotten more about these tractors than most of us will ever know!  I sent mine to him and we have a couple of good local shops (that have been bought out by big chain companies now...).
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 8:02am
Wow! Thanks for the kind words fellers! I just try to do a quality job at a fair price. Treat the customer how I want to be treated. Simple as that!I may not always be the "cheapest" but I am the best value there is!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA Luke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 2:35pm
Wow.  It's good to see this community stick together.  I'm so thankful for your opinions.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 5:32pm
You always treat me like a dog !!!!!
        IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 5:59pm
awwww...we all stilllove ya John! and I was about to ask the same questions as Luke...on my 190xt, he beat me to it! and as soon as I can go without the 190...i'll be sending my stuff to Ed too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 6:11am
        IG
Well, you are my little Biotch aren't you? lol! Now, I gotta get back to work, this broke down puller ain't fixxun itself!
