6000 coolant conditioner filter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 6000 coolant conditioner filter
    Posted: 28 Jun 2015 at 10:55am
Does anybody have pictures of factory mounted and pluming of the water filter and lines. Or if you have one on your 6000 how does it look. Going to put one on and figurd make it look good. Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 9:36pm
My 6080 has one.  It's on the left side, tucked up under the side shield, close to the cab.
No pictures, but it is a nice job.  None of it is visible with the shield on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 11:28pm
Also would it mater if I use a filter set up off a cat or Cummings engine. I can grabe one out of neighbors scrap bin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 7:07am
You can also just use the correct type of TREATED antifreeze and the problem is solved.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 11:52am
Make sure if you use a filter, you use the correct one for the type of antifreeze.  If you are using ELC (the red stuff), you don't want the filter with the SCA additives, you just want a plain filter.  If you are using the traditional antifreeze (green or yellow usually) then you'll probably want an SCA filter unless you are manually adding the coolant additive and testing it on a regular interval with the test strips.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 7:51pm
Ok thanks. Yea the ones laying there from the trucks are older and used green like tractor then ill get new filter to go with it.
This page was generated in 0.492 seconds.
