Bumfuzzled!!! |
Post Reply ![]() |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Jun 2015 at 5:25pm |
Ever since I got it, my Ford 8N has not charged correctly. Long story shortened, I got the genny rebuilt (it is a 6V system), installed a new 6V wiring harness and CORRECT 6V "A" Circuit regulator, polarized the generator, etc. The problem is the ammeter (which is good by the way) doesn't show charge until I gently tap on the regulator with a screwdriver handle or my pliers, etc. Once I tap it a little, charge rate pegs out at 30 amps for about 10 seconds, then stops. Then the needle goes back to 0 and stays there. I've tried 3 new regulators, and the same thing happens every time. And after a couple weeks, the battery is dead. I'm bumfuzzled! What's the problem here?
Thanks
Edited by CrestonM - 26 Jun 2015 at 5:26pm |
Wdtractorman ![]() Orange Level ![]() Joined: 24 Sep 2013 Location: Kentucky Points: 975 |
Iv had the same problem with a farmall cub. But I don't have an answer for you though. Be nice to know what it is
NDBirdman ![]() Orange Level Access ![]() ![]() Joined: 30 Jul 2011 Location: ND Points: 1441 |
Just shooting a wag here, no experience with this but, here goes. I have in the past had bad grounds do that. The gauge probably grounds and the mount, is the mount any way rusted/dirty/oily, or if grounded by wire, is it loose, frayed, rusty, have a green growth on it? Just guessing here, hard for me to figure it out without see'n it. Other than that, I don't have a clue, good luck with it.
Thanks, tried that this evening, made sure the regulator was a positive ground VR like the battery, still nothing, except when I tap on the VR....
slip knot ![]() Silver Level ![]() Joined: 15 Aug 2014 Location: texas Points: 103 |
Check the ground to the VR. Mine had a ground strap on the VR.
Lance/SC ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Lexington, SC Points: 411 |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34338 |
Did you put three new regulators on of the smae brand same number? Heard some of the new regulators are nothing but junk . Sounds like you rap it, and helps knock the points together and then it charges for a few seconds and releases and can't regulate. China junk? Dual polarity? Never understood those types. Good luck. andlet us know how you solved it.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
hillmonkey ![]() Orange Level ![]() ![]() Joined: 03 Apr 2010 Location: oville fl Points: 417 |
creston,you might reword your title to read something like "bumfuzzled,need electrical held on non charging gen". that way a person with electrical background/expertize is more likely to read your thread. good luck and let us know what the problem was when you get err fixed.
Post Reply ![]() |
