cylinder bar replacement.. when?
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Topic: cylinder bar replacement.. when?
    Posted: 25 Jun 2015 at 7:07pm
Having never replaced cylinder/rasp bars or held/seen new ones, what should I look for to tell or know when to replace them? Silly question, but I am relatively new to these combines.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 7:40pm
we replaced ours when we had the 66,when the rubber was eroding away from the leading edge of the bars.and wearing down on the rest of the bar.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 12:43am
Gleaners? If you look down the length of a new one,they have a high point down the center of the rasp and a rather square corner at the leading/trailing edge.When the leading edge gets rounded off they say they wont grab and pull material through.I'll say that the peak down the center is just as important for pinching and pulling stuff through as well.When the top is rounded off and the leading edge is rounded off you'll have a difficult time getting it to take anything through although they still don't do too bad in corn. Soybeans,forget it!A little hard surface on top of a rounded leading edge and a short bead across the center of the peak will help a lot.
