Who made the articulateds?
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Who made the articulateds?
    Posted: 25 Jun 2015 at 11:22am
I'm at an auction right now where there are several 8000 series and somebody looking at one of them claimed that it's got the same transmission (20 sp PD) as the Steiger.
He then went on to say that Steiger made all the large articulated for Allis like the 4w-305. I believe the 440 was a Steiger, but as far as I know the newer ones were engineered and built by AC. Or is there some possibility that Steiger assemble them for AC?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 11:51am
allis chalmers made two series for Stieger - sold them the "bogies"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 11:58am
Stieger made the 440, A.C. made the others themselves
Edited by DougG - 25 Jun 2015 at 11:59am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 12:55pm
Yup. Steiger made only the 440 for allis, it is 100% steiger with orange paint and a cummins engine. However, if you run accross a steiger with bar axles, the axles and transmission are supplied to steiger by allis for those units. Darrel
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 1:24pm
AC supplied Steiger with some driveline components. Hopefully someone with better knowledge will reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 2:12pm
Yes AC did supply axles , trannys and Powerdirectors to Stieger later on , prolly the late 70,s early 80,s when they were looking hard for outside business;
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 2:55pm
If I remember right it was the smaller 1000 series steigers, the last green ones before the Case IH models that had the Allis drive trains.
Edited by grinder220 - 25 Jun 2015 at 2:55pm
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 3:02pm
They have the AC 20 speed transmission in the stiegers in the 80s
    IG
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 6:39pm
The 20 speeds in nearly every steiger is a spicer 10 speed box,same as the semi trucks use,early model steigers used these for 10 gears and the later ones got 20 by having a 2 speed drop box to get 20, powershift steigers were allison transmissions
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 7:47pm
Except for the 20 speed transmissions supplied by Allis-Chalmers.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 8:03pm
Steiger wanted a couple models with bar axles and integrated pto's, this is where A-C came in and supplied the components. The ones that I've seen had an L10 Cummins engine. Can't remember about the dropboxes, but thinking they would've been A-C also. COUGAR 1280 is one model that comes to my mind. , Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 8:12pm
http://www.bigtractorparts.com/downloads/Stieger_Model_ID_thru1000.pdf
Starting on page 72
427435 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 10:19pm
Short story.  Two young engineers worked together at White Farm on the 4-150, and got to be friends and rode some motorcycle together.  One went to Steiger and one (me) went to Allis in the mid 70's.  We stayed in touch.
Steiger saw the need for some tractors with adjustable wheel tread and live PTO.  I got a call.  Allis had the transmission and drop boxes (2 needed) to do that.  Allis was also hungry for business, so we also took the 8000 final drive and made it into a "package" unit.
End of story.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 10:52pm
End of story.
Good story I think I heard that one before. I hoped you would set the record straight.
          IG
Edited by ILGLEANER - 25 Jun 2015 at 10:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 11:04pm
End of story.
          IG
Did I tell it over pizza in my kitchen??  Smile
Edited by 427435 - 25 Jun 2015 at 11:15pm
Mark
GTH-L Simplicity
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 7:50am
1985 CR and KR Cougar 1225 and 1280's were
the only two models. It was a one year wonder.
What is most interesting is that is this is the same
time period that Deutz owned a stake in Steiger
after purchasing the IH shares a couple yrs prior.
ALLIS CHALMERS "The color is orange"
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 8:05am
Interesting. I can't say enough, how much I enjoy reading about the rich AC history.
427435 - Thanks for sharing your incredible short story.
I have 2 questions;
1. what are bar axles?
2. What were the hp ratings for these Steiiger/AC models?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 8:36am
Bar axles are the normal round axle shafts most tractors use as opposed to outboard planetary axles. Horsepower was 225 and 280. Like I said before the smaller 1000 series 1225 and 1280 models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 8:47am
AC7060, Bar axles are an acronym for adjustable axles. Up until that time Steigers had outboard planetary (non-adjustable)axles. 225 & 280 were the hp ratings. Also on a side not these particular models have turned into orphan's, with a lot of the A-C parts NLA. In contrast to the earlier & later models that used truck components, Allison trans. etc., Mike
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 11:22am
there is a nice 85 kr1225 on tractor house with bars and a allis trans
remember plunder than burn
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 11:11pm
Hmmmm........got me thinkin. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 11:54pm
Looks like it even has AC wedges on the axel. That would look pretty cool painted orange sitting between my 220 and 305.......hhhhmmmmm
          IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 12:07am
Does anything in this photo look familiar?
m.tractorhouse.com/Picture/Index?listingId=9070889&categoryId=1108
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 12:11am
!!@&#! I did not realize my weblink was a group of photos, instead of just one...
Once the weblink photos appear, please scroll down to it's cab photos showing the gear shift console.
This page was generated in 0.056 seconds.
