Throttle not working on 7060
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: Throttle not working on 7060
    Posted: 21 Jun 2015 at 10:47pm
My 7060 with a foot throttle and hand throttle is not working right, with the hand in low throttle and going to high it works fine but when trying to return to low the hand throttle goes down but the engine speed stays high and the foot throttle stays down and you have to take your hand and force it up and the cable seems to work fine, any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 6:17am
Usually a new cable or WD-40 all the linkage the cable connects to inside the firewall. There has to be a spring to return the foot pedal....it isn't broken is it???
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 2:15pm
My 7020 would not return to an idle either. I took the forward foot plate out and found a large mouse nest in the open space underneath. It was holding moisture and rusted up the throttle linkage. Lots of PB Blaster and working back and forth got it working again.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 10:21pm
Do you suppose them mice will ever learn to go outside to PE and not in the nest?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 11:07pm
...I think it helps them find the bed in the dark.
