ac d17 gas hydralic problem
mayagent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mayagent Quote  Post ReplyReply Direct Link To This Post Topic: ac d17 gas hydralic problem
    Posted: 20 Jun 2015 at 12:31pm
went to pick up pallet of broken concrete about 300 lbs and after it got up in air it fell down and wouldn't raise, no pressure on lever now, checked rods under side panel and there till connected rod runs down center of frame with plates under frame. Any suggestions, i'm clueless about the d17. thanks please reply to my email at mayagent@frontier.com Any advice or help greatly appreciated!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 4:47pm
Sounds like what my WD45 did when the shoulder broke off the relief spool. Had to remove the pump and rebuild it with a new spool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mayagent Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 6:33pm
So how big of a job is that where is the pump and how do you remove it Thanks
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 8:13pm
I'd check the oil level in the HYD and  trans/rear end first, if you have lost hdy oil and now the trans/ rear end oil level is now over full then I'd look at the lift cyl or hose.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2015 at 9:31pm
I would agree with Don.  Start with the hydraulic hose that feeds the cylinder.  You need to pull the rear housing off the tractor to do that.
