Side Panel Bolts For The "D" Series
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Side Panel Bolts For The "D" Series
    Posted: 17 Jun 2015 at 11:23pm
Does anyone know where I can get the bolts to match the ones on the "D" series tractors? The bolts has a recessed head. Thank You.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 4:52am
Have you tried McMaster-Carr?  They have a pretty big selection.  I have a bunch of D-series, just having the panels bolted on, is good enough for me...
brettssac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettssac Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 6:54am
Older chevrolet oil pan bolts are identical
BX2,IB,WC,D15IG, D15IIDX3,D17DI,IID,IIID,IVD,D19DX3,D21II,HD3,185,AND GOD ONLY KNOWS THE EQUIPMENT
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 7:07am
Fastonal stores has them.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 7:16am
McMaster Carr has the identical bolts, they have the recessed head and the toothed lock washer already on them.   They have an easy to use on line catalog too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 11:07am
I had no luck with Fastenal, but McMaster Carr had them.
If anyone would like to order some here is the part #90401A537.
1/4"-20x1/2" 50 per pack.
Thanks & God Bless
Dennis
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 7:36pm
What about ones for a B?
