Model 90 loader ?
MARK W (NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MARK W (NY) Quote  Post ReplyReply Direct Link To This Post Topic: Model 90 loader ?
    Posted: 16 Jun 2015 at 9:55pm
A couple years back i pick up a Model 90 loader at an auction for $40.   finially got it on the Wd today , added some hydrolic fluid and put it to work for a few minutes then noticed fluid leaking out the bottom of the engine clutch housing where the inspection cover is. I am assuming i had overfilled the hydrolic fluid although it had read good on the cap,  Any Thoughts  ?  right now it has a manure bucket on it, I would like to find a bigger  bucket for it.
Its a Great Life if you don't weaken
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 8:28am
Back in the day, my Dad had a New Idea-Horne loader on a WD. There was an extra oil reservoir mounted along the tractor side rail at the same level as the oil in the tractor.
There can't be much oil left in the tractor with the loader raised up. You likely overfilled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 8:45am
Yep, prolly too much fluid in the reservoir. With my W9 loader on the 45, I don't need any level above full to raise it completely. Check with lift arms extended and loader on the ground.
This page was generated in 0.073 seconds.
