D-17 series IV spline brake hub
redpower1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redpower1 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 series IV spline brake hub
    Posted: 16 Jun 2015 at 7:36pm
Does anybody know how to remove the spline brake hub from the bull pinion shaft? There is a wire snap ring inside the hub that doesn't want to come out and thinking about just heating and pulling the hub off the shaft hoping the snap ring will collapse enough to let the hub loose. The IT book says remove(pull) hub, then woodruff key, then snap ring.Angry
D-17 series IV serial 86206
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 8:28pm
Series IV brake hubs should slide off the axle shaft with not much force. A little wire brush action. The key is in earlier models with a solid drum.
Edited by jlogli - 16 Jun 2015 at 8:31pm
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 8:32pm
Series 3 and 4 have a splined hub that is pressed on the axle shaft. I don't ever remember having to remove/replace one. It will take a puller or heat or both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 8:36pm
I thought series I and II were pressed on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:12pm
Series 1 and 2 had the brake drum pressed on. Different design of brakes.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:23pm
the splined hub on a Series IV is a loose fit on the splined shaft.  It is supposed to be able to move on the shaft a little as the brake discs wear.  Yours may be rusted, there is no snap ring or half moon key on a Series IV.    Worst comes to worst you may have to pop the springs holding the drum halves together and separate the splined half from the open half-not a fun job.    Ive done lots of them, never had a problem removing the drum from the shaft, always a new wrinkle somewhere.  Now the pin that holds the two bands in place is an altogether different story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:29pm
Unless I've lost my marbles, the 180-185's had the brake drum splined directly to the axle shaft. The D-17 3 and 4 used a different drum on the splined hub that was keyed to the axle shaft, yes??
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:42pm
No,  the brakes in a Series IV are the same design as a 180 or 185.  On all those tractors the final drives are outboard-hence the same direct splined axle setup.   D19s and 190s and 200s have the brakes splined to the pinion shaft as they  all had internal final drives.  Been a long time but I think the brake discs are the same part number for series IV and 180/185.    HTH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:47pm
Brake disc linings are the same from D-17 3-4 170-175-180-185. Better look on AGCOPARTSBOOKS.com. The brake drum is different, as is the axle shaft. My theory is the 180-185's wouldn't have survived with the half-moon key cut in the axle shaft, so they eliminated it. The lower HP tractors still used a key and then a splined hub to a different brake drum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:47pm
Yes Dock you are right, it uses the same axel as older tractor. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 10:06pm
Agco parts: lineing for D17IV-237421,  Lineing for 180/185-237421.  The outer drum is the same P/N, the splined drum is a diff part number.   There is a splined adapter that is keyed to the axle shaft that the inner drum sits on.  And the brake bands are 235610 on all those tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redpower1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 4:11am
I'm referring to the retaining ring(p/n:70230330)for the brake hub(p/n:70237219) that I can't remove.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2015 at 5:12am
Looks as if you could appy some heat to the hub and slide it one way or the other, then take the snap ring off.  Heating  the snap ring will probably ruin it- might have to do that. I think the IT book is referering to the brake drum on early D17s.  I remember the AC D17 service book didnt cover Series IV brakes,  Id go the 170 book for that info.   Maybe later D17 serv books had those brakes in it, mine did not.  Good luck
