Need help on C and WD
boilerpete View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerpete Quote  Post ReplyReply Direct Link To This Post Topic: Need help on C and WD
    Posted: 16 Jun 2015 at 5:43am
On my newly restored C, I couldn't get the engine up to running RPM.  So I took the governor apart and discovered the bushing in front of the grooved bushing was missing.  So I assume that's the problem- nothing pushing against the fork to rev it up.  Have one replacement bushing coming this week.  Here's the problem:  in working with it, the governor shaft shifted forward about a half inch, and now the cover won't go back on.  I don't see how to back it into the housing without taking the whole front end apart down to the timing gear.  Any advice from someone who's been down this road?
On my WD, I haven't changed tranny fluid in many (many) moons.  Like never.  So I decided I'd take that one on.  The fill plug has a square head, appears as though a 5/8" wrench will work.  Except that there is no clearance between the plug and the side rail.  So I need a socket that works on a square head.  Will a 12 point socket do the trick?  If not, how do I get that loose (since it is firmly rusted in place)?
Thanks!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 6:36am
You just need to remove the magneto. The drive slot is hitting on the drive lugs. No way to get it any other way and still be in time. After you have removed the magneto set the flywheel to TDC on the compression stroke. You then can set the governor gear back in with the drive slot horizontal. After the governor assembly is bolted back up you can back the engine up to or past the FIRE line and set the magneto with it ready to fire to number one plug. If you first remove all the spark plugs it will be easier to turn the engine over. Most but not all governor gears have a flat head screw behind the magneto to keep the gear from moving forward as yours has.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 7:24am
Some PB Blaster might help. I think you can use a 12 point socket on that plug 5/8 sounds about right. A 8 point would be much better.
Edited by Sugarmaker - 16 Jun 2015 at 7:25am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 9:56am
12 point sockets made only for hex heads will take the corners off the square plug. They do make 12 point sockets specifically for both hex and square. They do make 8 point and 4 point sockets specifically for square. If not available locally, try www.mcmaster.com
Gerald J.
This page was generated in 0.079 seconds.
