D15 series II handle a 6' bushhog?
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: D15 series II handle a 6' bushhog?
    Posted: 15 Jun 2015 at 3:57pm
Question: our 5' 3 point bush / brush hog has seen better days.
Will our D-15 series 2 handle a 6 foot hog? Weight and shaft HP wise? Does fine with the five foot.
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 4:30pm
Depends completely on what you are cutting. Most things my 15 would be fine. Tall grass would be too much.
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 4:32pm
You don't have to take a full 6' cut
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 5:24pm
I used a very tired D15II SC on a 5' A-C brush cutter (3-pt. and I use A-C adaptors) and it was used to take down up to 2"+ trees when initially clearing my place. Bought a name brand 6' cutter (SQ72) that shows to weigh just over 1100# and she runs it fine. Front end can get a bit light and I run tall rear tires but they are nicely sized for each other, even when used in 6' tall grasses/brush on mowing jobs.
Just keep that 160ci wound up to full or near full throttle and I cut 12 hour days in 2nd, low range on the PD without issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 5:47pm
I would say yes, it will handle it weight wise.  If you are going through thick sh!t, just take a partial cut...
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 6:06pm
yes, we have used a Woods 6' for years
Charlie
