3 position light switch
swampy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampy Quote  Post ReplyReply Direct Link To This Post Topic: 3 position light switch
    Posted: 13 Jun 2015 at 8:44pm
I have a AC C me and my boy are restoring I have a new 3 position switch and try to find out how to wire it has 3 lugs for wires but no marking on it thanks for any help Tony
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 9:04pm
If you look at the switch closely, one of the lugs should be connected to a resistor.  That lug needs to be connected to the wire that goes to the "F" terminal on the generator.  The other two lugs are basically electricity in and electricity out to the lights.  One of them should be connected to a fuse.  Hook up the electricity supply to the lug connected to the fuse.  Electricity out to the lights should be connected to the remaining lug.
Edited by DanD - 13 Jun 2015 at 9:07pm
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 9:22pm
Here is a link to an old post that may be helpful.  Is for a WD but wiring is the same.
http://www.allischalmers.com/forum/forum_posts.asp?TID=74939&title=3-position-light-switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 8:55pm
Be careful with those aftermarket light switches. They don't fit well in some of the instrument boxes and can short out and burn up the system.  We have an exchange program going on the OEM AC Delco switch which was original equipment to the AC machines....
Steve@B&B
This page was generated in 0.062 seconds.
