how to use a transport valve |
playsindirt
Joined: 13 Feb 2011 Location: west michigan Points: 159 |
Topic: how to use a transport valvePosted: 13 Jun 2015 at 7:42am |
I would like to know the right way to use a transport valve.
48G 49B 67D15 35picker allcrop60 1973 rotobaler 49C
DanD
Posted: 13 Jun 2015 at 8:29am |
First things first. Are you pulling a mounted implement with its own transport wheels such as a large disc or a plow with a trailing wheel?
playsindirt
Posted: 13 Jun 2015 at 1:49pm |
yes i am pulling a 10 foot disc with wheels and hydraulic cylinder.When i raise my disc the 3 point has to come up and then the disc goes up. It is hard to time all of this to turn around at the end of the field. Thanks
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 13 Jun 2015 at 4:20pm |
What tractor would be helpful as well? The D series have different valve than the say WD/45s
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 13 Jun 2015 at 4:25pm |
Raise the lift arms and tie them up so they can't go down. Then go disc your ground. I've done it for years. Forget the transport valve.
DanD
Posted: 13 Jun 2015 at 8:07pm |
But, this sounds like you do not have a mounted disc with wheels but simply a pull type disc attached to the draw bar. If that's the case, the transport valve does nothing for you. I'm assuming you have a D17 or WD45 or something with a snap coupler hitch and one hydraulic outlet since the lift arms are controlled by the same lever that controls the lifting of the implement. Edited by DanD - 13 Jun 2015 at 8:09pm |
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 1003 |
Posted: 14 Jun 2015 at 8:51am |
I think it sounds like a pull type with traction booster.
Life is simpler when you plow around the stump.
DanD
Posted: 14 Jun 2015 at 9:30am |
I don't think so because the rigid links on the traction booster draw bar would prevent the lift arms from going down...which is the poster's main complaint...that it takes too long for the lift arms to raise all the way up when lifting the implement. A picture here would be worth 1000 words!!! LOL |
playsindirt
Posted: 14 Jun 2015 at 9:39am |
thank-you all for the responses. I have a d15 series 2 and i am trying to keep the lift arms up when i am pulling a disc. I am also using a dump trailer and when it is empty the hydraulic cylinder on the trailer extends before the 3 point goes up.
DrAllis
Posted: 14 Jun 2015 at 9:58am |
Take a piece of rope and tie the lift arms "UP" to the back of the seats suspension frame. One lift arm will probably do.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 14 Jun 2015 at 10:04am |
Beyond all that,the transport valve, when backed out,sends oil to the remote cyl first then to the lift arms.There's a pressure differential but I don't know what it is.If the valve is screwed all the way in ,it will be the same as not having one and the port with least resistance will act first.
DrAllis
Posted: 14 Jun 2015 at 10:26am |
All the way out (counter-clockwise) sends oil to lift arms first (to utilize the Traction Booster feature) then the remote ram. Clockwise (all the way in) is for normal operation.
