D-17 Governor & PS parts
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Governor & PS parts
    Posted: 07 Jun 2015 at 7:00pm
I need governor weights, pins & thrust bearing plus some power steering parts - needle bearings, oil seals & drive shaft bearing. Any suggestions who to contact for parts?
Thanks for any help.
Stanley
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 7:03pm
  DJS TRACTOR PARTS[MICHIGAN]  734-320-3470  TELL HIM NORM TOLD YOU TO CALL
   DAVE IS HIS MANE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 8:03pm
Thanks Norm. I'll call him tomorrow.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2015 at 8:35am
Here is some info on the needle bearings and seal.
You may not need this because it appears that DJ's probably handles all the stuff you will require.
Seals (2): A-C #0229372-8  National #450023  I.D. .625"   O.D. 1.375  Thick. .406"
Needle Bearings (4): A-C #0800781-7  Torrington #B-108   I.D. .625"   O.D.  .8135"
Thick.  .50"
Ball Bearing (driveshaft)  A-C #0229508-7  This is the very common 203S bearing
used in automotive applications.
Not knowing at the time the source Norm refers to, I searched around the internet for my bearings and seals except for the ball bearing which I happened to have "in stock".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2015 at 8:40am
Brian-KS posted this in response to your original post.
Brian-KS View Drop Down
Status: Offline
  Quote Brian-KS Quote  Post ReplyReply
Direct Link To This Post Posted: Jun 03 2015 at 5:34pm
I think Rick is spot on. I wouldn't run the tractor anymore until fixed. You run the risk of broken material breaking teeth off the governor gear or the camshaft gear. I have a NEW set of weights and pins, left over from a project that changed course mid stream, that I would be willing to sell. PM me if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2015 at 10:08am
My parts have been sold, thanks
EAT BEEF!
This page was generated in 0.166 seconds.
