M&W Pistons
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: M&W Pistons
    Posted: 30 May 2015 at 6:18pm
I know this has been discussed before, but, does any one know what company was the last to make the M&W Power seal engine kit was? Seems i remember they quit making them? Sure would like to find a set for a 8070.
Thanks
Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 11:41pm
Sealed Power.They called them Power Seal.They only made a run every so often when they had enough orders.Did they officially quit them?
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 11:45pm
Herschel is the companies name    www.herschel.com   1 800 247 2167      they are part of the Alamo group , were the old M&W co. went. I am A dealer for them, I can't them either, maybe if enough people call them, & rattle there cage, it will help bring the kits back on the market.   GOOD  LUCK
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 7:09am
Tom's Agri Diesel in Iowa has a high compression kit for AC's.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 7:17am
Thanks, will call both numbers tomorrow. Any body have any experience with Toms agri diesel?
clintr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clintr Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 10:25am
They are good to deal with have used their parts several times where I used to work.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 11:39am
You may not be able to deal with them directly. I believe that they have been purchased by Howard Enterprises of Indiana.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 12:25pm
I order kits from them for customers where I work. If you can't buy direct from them let me know.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 12:31pm
And they are pricey!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 12:49pm
..the good stuff always is.Got em in my 220 & 8070.
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 1:24pm
What?
Who do you order from, and what have you been getting?
I had no idea you guys dealt in parts like this!
There isn't much a WC can't do.
WD's just do it better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2015 at 9:14am
I did some checking today, Hershel Adams told me that the plant where they got M&W power Seal kits did burn down and all molds were lost, had hoped that was not the case, now am checking with Toms Agri Diesel. Thanks for all the help.
Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2015 at 9:18am
Well that right there stinks!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2015 at 9:52am
Tom's Ari Diesel 712-799-4233
Part numbers for a 7080
Minpar rings
Reliance pistons
        sleives
        pins and retainers
Kit number 111123
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2015 at 7:28pm
Randy
Gee, I guess this means when I tear down my WD45 engine - the pistons go off to a custom maker.
They were Pow'R Seal, and were a measured 8.2:1 compression.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2015 at 10:24pm
Randy
I put a set of Power Seal M&W knock offs in my 45 and they were 6.5 C/R instead of 7.25 like the real M&W's I replaced.I don't remember(been a while)but it seems like they were listed as WD45/D17 replacement.Maybe yours were for 175?They did NOT advertise C/R.I did a crude CC of bowls and the new ones held abut 10cc's more.Rough math indicated the stock 45 C/R on the new stuff.You call tell the difference on a hard load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2015 at 5:29pm
I bought mine in '93 at the Louisville Farm Show. The guys were in a small booth that had signs to the effect "M&W Add-Power".
The boxes said "Pow'R Seal". It was mostly Farmall stuff.
I asked about M&W parts for Allis' at the time and I believe they said they had been "bought" by another company and were selling as much of the old inventory stuff as they could at Louisville and other farm shows. I asked about a '45 sleeve piston kit - and the one I have is the last one they had then, cost me $290.
The guy brought the box out from under a table, and the other attendant remarked that some other guy (can't remember the name) "was going to kill you for selling those!".
I can understand why, I reckon these pistons had the extra compression point yours didn't.
I didn't put them in an engine till '2000 or so. They've been run hard for many hours and need a revisit. Never had a problem with them, stoutest farming WD I've ever sat on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2015 at 12:16am
My dad was the local mechanic.He used to keep M&W kits for WD&WD45 on hand. He passed away in 2000.Last year cleaning out some old stuff from the "still useable section" I happened upon NOS WD M&W's. Not gonna sell them for any price.Also found a set of used 45 M&W's pistons that look a good bit better than the one's I replaced.Considering slappin them in with a set of rings and get my old tractor back.
