allis 770 air champ
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: allis 770 air champ
    Posted: 28 May 2015 at 3:27pm
I just have a question about the 770 air champ, I picked one up cheap and I was wondering if there is any pros or cons to these planters? also I am in need of 4 seed hopper lids these are all missing. thanks in advance
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2015 at 5:30pm
hopper lids are the same as the later unit = you will pay more for them than the entire planter. The fans must be clean and with seed in the plates you MUST have 2 water columns of pressure. You can make a cheap manometer to measure this. Check the cut off pads.
Moving the scrapers to below centerline and at a 90 degree to the opener will greatly help.   The little chains are probably frozen and will jump - replace them and the #32 chain as well.
We always used the med small plate for soybeans they are   stamped # starts with 15....
This page was generated in 0.060 seconds.
