180 pto problem |
Post Reply ![]() |
AndyinWI ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Blue Mounds Points: 416 |
![]() ![]() ![]() ![]() ![]() Posted: 26 May 2015 at 11:08pm |
I just put a new clutch I my neighbors 180 allis and now the pto doesn't work. It was working before I split the tractor. All other Hyd functions work like they should. Any help is appreciated.
Andy |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21909 |
Well, we have a choice of TWO clutches......foot clutch......hand clutch. If you installed a new foot clutch, I see no connection between the repair and the PTO problem. Hand clutch ??? Yes, probably need to manually shift the short lever behind the battery box back into gear.
I replaced the foot clutch. It has the Hyd pto and I was figuring it has something to do with having the lines apart when I split it.
I'd still check the PTO coupler shifter behind the battery box...rotate fully counter-clockwise to engage. Someone might have to turn the shaft at the rear of tractor while you shift the lever.
Post Reply ![]() |
