Oh the joys of old tractors. LONG.
1mathom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1mathom1 Quote  Post ReplyReply Direct Link To This Post Topic: Oh the joys of old tractors. LONG.
    Posted: 18 May 2015 at 10:18am
I know NONE of you can relate to any of this.
A few years ago I bought a '38 B to play with but things being what they are, haven't had time to spend on it till lately.   The seller was a friend and good mechanic so even though the carb and mag were in a box and my buddy said there was some bearing nose in the left final drive, I wasn't too worried.... but he hadn't really owned it that long....hadn't done any work on it really. Few odds and ends to sort out for the correct police but nothing big. I could tell someone had done a few things...added a three point with a few homemade parts (works fine), fuel line, JB weld on the air cleaner cup....that kind of stuff. Not unheard of.
Well, I cleaned and rebuilt the carb, put a little Marvel's in each cylinder, new plugs, cleaned and timed the mag (which was a later model X mag), cleaned out the tank, primed the oil pump and she started up after a few pulls and maintained good oil pressure. No smoke after burning off the Marvel's.     Cool.
So I am playing with it...putting around the area.   Wait...do I hear a rod knock? What is this wet stuff blowing all over?   Yep, water pump is dumping it out as fast as I can pour it in.
So, I get a water pump and begin swapping it. Hey....why does this crankshaft pulley flop around? Why isn't it tight?   OK, pull the grill and radiator. Put a wrench on the crank bolt....snap. Breaks off flush with the surface of pulley boss. Cobalt drill and an "easy out". Snap. "Easy out" breaks off even with the top of the broken bolt.   Maybe I can shatter the easy out stub with a good hard, sharp punch. Of course NOT. It just drives deeper in the hole. OK. Dremel tool and little grind stones...and time. And more stones. OK. Finally grind out the EO stub. Drill on through the bolt with successively larger bits and get the pulley off. Oh, by the way, none of the four studs and nuts holding the radiator support on the front of the motor are the same. What the...??   Hey, WHERE is the woodruff key on the crankshaft? What the...?? The keyway in the pulley has a big chunk missing! The bolt has been just cranked down hard right over the crank key slot...and has been wallowing out the keyway.   I bet THIS is what I have been thinking is a rod knock!
So...now to figure out how to repair the crank and find another pulley.
AND A WOODRUFF KEY.
Hope you have had a chuckle.
(....and we are still friends. He had not done any of the "work" on the crank.)
Edited by 1mathom1 - 18 May 2015 at 10:26am
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 10:42am
Sounds perfectly normal LOL
EAT BEEF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:42pm
Yup! The biggest thing wrong with something mechanical is the guy that worked on it before you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:44pm
Isn't this the definition of "snowball"?????   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
GaryL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 12:54pm
As a friend of mine says about old tractors, "The damn thing has been farmered to death."
Karl in MD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl in MD Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 2:16pm
One tip:  When you break a tap or an easy-out, get your handy-dandy little torch (bernzo, oxy-acet, or whatever), heat the broken gizmo up as hot as you can get it, then let it cool very slowly.  The process may have to be repeated.  This will anneal the tool to where you can drill, grind, chisel, etc. it out easily, and without buggering up the surrounding part.
A man's got to know his limitations.
'51 WD, Roto-Baler,, A-C rake, '44 C, '42 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl in MD Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 2:19pm
BTW:  I'm not a metallurgist, but I play one on TV.  Actually i'm just clumsy and I break a lot of tools.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 4:33pm
And heating the ezout inside the other steel, it will want to expand while its hot, but while its hot its weak and the other cooler steel keeps it from expanding, then when it cools it shrinks and is often loose in the hole. That's why welding a washer and a nut to a broken bolt works so well. The welding heat does that softening and squeezing and shrinking to the bolt.
Gerald J.
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 4:53pm
At least it wasn't a hose clamp holding a square key on a shaft....
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 8:36pm
I can definitely relate.  Good story.  As some would say, "been there, done that."
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 9:32pm
Stuff like that happens to me on a good day. Most days it's worse. Darrel
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 11:38pm
i'd better stay away from Darrel, he don't needs any help!
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 6:09am
Another reason that I am not interested in buying a tractor that has a pretty paint job.
If I am going to go through all that I don't want to mess up pretty paint.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 6:27am
That's just part of the equasion when it comes to buying old Tractors. You never know what to expect! In most cases, you'll get a surprise...LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 8:23am
SHAMELESS, you thinking that if'n we were to work together for a day, that by the end of the day, we'd be about a week behind? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 5:52pm
When I bring a new project home I try to keep my expectations pretty low:) Yes these last two WD's have been farmered to death! But both are family tractors. So have put up with a lot of the surprises!
