c transmission problem
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Topic: c transmission problem
    Posted: 10 May 2015 at 5:44pm
My 48 C will not stay in third gear unless you hold it in place. Any help would be appreciated.  Do you think the problem is  in the shift cover or in the transmission ?
Richmar
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 6:49pm
Shifter could be wore or slightly bent. You can take the rubber boot off and remove the snap ring(the tricky part ) and remove the retainer thingy and pull the shifter out. It should be obvious upon inspection if the ball on the end is noticeably wore or if the shifter isn't straight.
 The problem might more likely be in the forks on the side cover. You have to drain the tranny to pull the cover and inspect . You can also inspect the gears with that cover off.
