7060 AC a/c
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: 7060 AC a/c
    Posted: 27 Apr 2015 at 11:25am
For the past few years, excluding last year, I would take my 7060 to my auto mechanic to have the air conditioning charged and it would last most of the season. He evacuated it and charged it last week and we discovered the compressor won't engage. I've checked and have power at the switch. I was thinking fuses but found out after looking for too long that there is no fuse panel on the tractor. I looked at the big breaker set on the firewall and didn't see anything obvious. Is there anything else I should check or is it probably time to replace the system? It is updated to 134 coolant.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2015 at 12:29pm
Power comes from the thermostatic switch under the cab roof, so check there first. There is a plug-in connection behind the engine/in front of the cab for splitting the tractor that will get rusty/corroded and stop your flow of electricity to the A/C clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2015 at 12:39pm
Thanks doc, I'll check that out.
