8070 rear main seal leak |
   N6PETE
   Joined: 02 Jan 2010 Location: Camanche, Iowa Points: 227  |
      Quote   Reply
     Topic: 8070 rear main seal leakPosted: 23 Apr 2015 at 8:16pm  |
   My rear main is leaking on my 8070, I am getting a small oil drip of motor oil out the hole in the bell housing. The strange thing is the drip gets worse after I shut the motor off. I am not losing that much oil, it makes more of a mess than anything. Questions Why does it leak more after the motor is off? Oil pressure? Also, do you have to split the tractor to replace that seal?
  Thanks  |
   MACK
      Quote   Reply
     Posted: 23 Apr 2015 at 9:55pm |
   Flywheel is sturing oil running, then it runs down when shut off. Yes it has to be split to replace.   MACK
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
