AC WD won't start
HVFDFIREFIGHTER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Topic: AC WD won't start
    Posted: 14 Apr 2015 at 5:23pm
Finally got above 60degrees. Had a chance to look at tractor. Started right up. Ran for about 5 minutes. Then stopped. Can't get it started again. Didn't have time to mess around. What could be wrong? It was running great, then suddenly off. No chugging or gasping or anything, just stopped. Check wires quickly? All seem to be on. Small Wire to starter was loose and hot, tightened but still not starting.
Any help or ideas would be greatly appreciated.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 7:15pm
Turn gas on.  Put gas in it.
The universal answer to all questions is yes, how much do you want to spend?
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 7:19pm
condenser?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 7:45pm
open drain on carb and see if you have good flow of gas. Let it drain a few minutes to be sure there is nothing in the tank floating around and plugging the outlet of the tank.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 8:37pm
    Check the oil ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 9:12pm
Thanks guys. I thinking it is a gas issue. I will check when I get a chance.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 9:16pm
Drain the water out of you sediment bowl. Pull the carb drain and give it fresh gas. It'll start right up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 7:39pm
OK! Go ahead and laugh! I feel like a idiot!
Gas tank was bone dry.
Put some gas in the tank, and it fired right up! Funny how it likes a little drink now and then.
I was thinking, gas in the sediment bowl, so it has gas, duh, th sediment bowl is lower than the gas line!
When in doubt, check the obvious!!!
Edited by HVFDFIREFIGHTER - 17 Apr 2015 at 7:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 7:40pm
Thanks Dave! That was the problem!
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 8:30pm
good one!... glad it worked out!
   David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2015 at 8:08am
Bin There done that. LOL
