D15 II Wiring ignition back up
dustinmars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmars Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Wiring ignition back up
    Posted: 06 Apr 2015 at 9:48pm
I have restored my 15 and putting it back together now and just needing to wire it back up. I'm doing a negative ground system with a key switch and push start switch, also one wire altenator. Could anyone please share a wiring diagram if you have one. I would greatly appreciate it!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 6:10am
See page 73 of attached link for D-14 original Wiring Diagram ( 6 volt with Gen., push-button starter button )
Gary
http://www.grandpastractor.com/manuals/D14/d14part3.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 6:23am
Leave the one wire Alternators to Automobiles and hotrods. Most 1 wire Alternators can be changed over to a 3 wire. Read the article I wrote on the subject on our website. It'll shed some light on the subject. Get yourself a manual on your Tractor. There are wiring diagrams in the manuals that you can use for a guide. If you need any more help, give me a call. I'd be happy to walk you through the wiring to correctly wire your Tractor.
Steve@B&B
bb-customcircuits.com
