Hour meter
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Hour meter
    Posted: 26 Mar 2015 at 2:54pm
I would like to add a hour meter to my B and CA, and probably all my AC's that don't have a tach.
Suggestions? This would be something simple, under the hood that I can peek at to check the hours.
I have one on my Dirt Bike that wraps around the spark plug wire and keeps hours. would that work?
Charlie
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 3:39pm
I believe you can buy an electric hour meter that is not much more than a 12 volt clock, if your tractor has been converted to 12 volt.
I have an hour meter similar to this on my Honda EU2000i generators.
http://www.northerntool.com/shop/tools/product_200624883_200624883?cm_mmc=Google-pla-_-Engines-_-Small%20Engine%20Accessories-_-160595&ci_src=17588969&ci_sku=160595&ci_src=17588969&ci_sku=160595&gclid=CPKNhbXvxsQCFfRj7Aod9U4AqA
It picks up an impulse from the spark plug wire. It works well on the generators. I don't know why you couldn't use one on a gas tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 6:03pm
Google tinytach.  They have several options, some even have service reminders on them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 8:48pm
This is the hour meter I was talking about in the first part of my post. Unlike most tractor hour meters, they will not take engine speed into account (an hour at rated PTO speed), but are really like a 12 volt clock.
A lot of industrial equipment has this type of meter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 5:13am
Thanks for the help!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 6:10am
Just a heads up !
Had a tinytach in one lawn tractor, display went 'dead',hmmm.....TOTALLY SEALED...couldn't replace battery !!!!
Hopefully they have better units now( I haven't checked), after that bad taste in mouth decided to make my own 'operation meter' for my D-14s.Big LCD display,2 wire hookup,etc....
Jay
