WD45 POWER STEERING PROBLEM
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 POWER STEERING PROBLEM
    Posted: 20 Mar 2015 at 6:42pm
A friend of mine put a WF and power steering on a wd45, his problem is tha tit wanders all over the road, he has blead all of the air out of the lines, so do you think the trouble is in the PS PUMP or the front Gearbox? thanks for any help..Tom
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 7:19pm
You will have to get inside the pedestal and find where the slop is and fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 7:39pm
He might have the front wheels toed in or toed out. There's several things it could be and not be the power steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 11:38pm
wrong toe will make them like snail darters.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 12:50pm
Needs to be toe in about 1/4". Toe out will make any vehicle wander badly. To much today in wears tires but will still drive ok.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 1:41pm
Jack up the front end and grab the front tires and give them a shake to be sure there is no slop.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
