7000 issue
edard12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edard12 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 issue
    Posted: 17 Mar 2015 at 8:30pm
Just got a 7000. It has a transmission issue. Only moves in 1st and 2nd gear. Seems like it doesn't have enough hydraulic pressure. Is there a way to turn up the pressure or is there something bigger wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2015 at 9:15pm
How do you know the foot clutch isn't slipping??   The age or serial number would be helpful. Is the gearshift on the floor???
Post Options Post Options   Thanks (0) Thanks(0)   Quote edard12 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2015 at 9:32pm
It's a maroon belly. Shifter on floor. I'm told it has a dry clutch in it. New to AC farm tractors. Sorry I'm asking stupid questions. Can't learn if I don't ask. Seems to work a little better the longer it runs, until it gets a load on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2015 at 9:38pm
I'd bet the foot clutch has ZERO freeplay causing it to slip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote edard12 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2015 at 10:29pm
I didn't drive it my nephew did. So is the fix a new clucth or just an adjustment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2015 at 7:19am
If there's no clutch pedal freeplay, I'd sure try to adjust it before it eats the throw-out bearing and thrust bearing on the crankshaft.
This page was generated in 0.054 seconds.
